Forum Machete,Modelism,Hobby: CINE ARE SETUL DE MUNITIE MINIART 35090 SOVIET INFANTRY AMMO BOXES - Forum Machete,Modelism,Hobby
#1 Useril este offline   caporalmusat
  • Postari: 1048
  • Inregistrat: 03-January 09
Postat 28 June 2011 - 04:36 PM
SALUTARE ! ASA CUM SPUNE TITLUL TOPICULUI AS VREA SA MA LAMURESC LA CE FOLOSEAU ACELE CUTII METALICE DIN SET CE TIP DE MUNITIE ERA IN ELE SI DACA ARE CINEVA ACEST SET SI VINDE CUMVA O RAMA CULEU CU O ASTFEL DE CUTIE SI LADITA DE LEMN DIN ACEL SET SAU MA POATE AJUTA CU DIMENSIUNNILE LADITEI SAU CINE VREA SA NE CUPLAM SI SA LUAM UN ASTFEL DE SET AM AVUT BAFTA CA IN ARMATA BATERIA NOASTRA SA AIBE IN DESERVIRE DEPOZITUL DE MUNITIE SI AM CARAT LA LADITE DE ALEA DE MIA VENIT ACRU LA ALARMA INCARCAM / DESCACAM JUMA DE DE CAMION ERAU PT MUNITIE DE ARME DE 5'45 SI 7'62 DE TOATE FELURILE BA CHIAR IN 96 AVEAM SI LAZI ORIGINALE ADICA PE ELE SCRIA IN RUSESTE SI CAND MI AM INTREBAT PLUTONIERUL CE ERA CU NOI MIA-A ZIS CA MA MANINCA SPINAREA ; ASTA E CU SICRETUL . BUN SA REVENIM LA SUBIECT LADITELE SUNT CA CELE REALE DAR CA DIMENSIUNI DACA OR FI SI ALEA BUNE CAM GREU DE AFLAT ASTA DAR CA MACHETA NU; PAREREA MEA , DUPA CE AM VAZUT POZELE RESPECTIVELOR CULEE VALABIL SI IN CAZUL ALTOR SETURI IN CARE SA FACI LAZILE IN LEMN NATUR SAU CHIAR SI VOPSITE IN KAKIUL RESPECTIV .
SA EXPLIC CE MI SE PARE MIE AIUREA LA ACESTE LAZI : SCOATEREA IN EVIDENTA A FIBREI LEMNOASE PRIN ACELE GRAVURI IN PLSTIC DE ZICI CA E FACUTA DIN SCOARTA DE COPAC GEN SALCIE , STEJAR " LEMNUL LAZII " ASTA NEPUTAND FI ADEVARAT PT CA LEMNUL RESPECTIV ESTE PRELUCRAT IN MASINI DE TAMPLARIE IN FELUL URMATOR : SE DEBITEAZA CHERESTEAUA (SCANDURA ) LA ANUMITE DIMENSIUNI BRUTE SE FACE VINGLU- CANT LA ABRICT (MASINA DE RANDELUIT) ADICA SE FASONEAZA O FATA LATA SI O GROSIME APOI SE IAU LA MASINA DE DEGROSAT SI CEALALTA FATA LATA SI GROSIME , FIIND SCOASE SI LA DIMENSIUNILE NECESARA LATIME SI GOSIME , DUPA CARE SE DEBITEAZA LA LUNGIMEA NECESARA SI APOI URMEAZA ANSAMBLREA LAZII FIIND PRELUCRATE CU ACELE MASINI ELE (SCANDURILE) AU UN FINISAJ SNT LISA(NETEDE ) BINE NU CA LA CELE LACUITE CARE SE SLEFUIESC SI LACUIESC SI ATUNCI DE UNDE SCOT ASTIA ACELE RIZURI CARE SI-N CAZUL CELOR VOPSITE RAMANE ASA CEVA FIIND AIUREA LA SCARA RESPECTIVA 1/35 . SAU MAI APARE ACEL LUFT (SPATIU GOL) INTRE SCANDURI ALA E DE 1.2. 3 MM CUM SA-L SCOTI SI PE ACELA LA SCARA RESPECTIVA .
IN CONCLUZIE EU ZIC CA IN CAZUL LAZILOR DIN LEMN NATUR TREBUIESC FACUTE CHIAR DIN BAGHETE DE LEMN PT A RESPECTA REALITATEA SIN CAZUL CELOR VOPSITE CHITUITE PT A INCARCA RIZURILE SI APOI VPOSITE SI FACUTE EFECTE ,NU CUM ARATA CELE DIN GALERIA LUI MINIART SI REVIN LA EXPRESIA SCOARTA DE COPAC .ASTA E OPINIA MEA BAZATA PE FAPTUL CA MESERIA MEA AFOST DE TAMPLAR SI PT EXEMPLIFICARE MERGETI INTR-UN MAGAZIN GEN PRAKTIKER SI VEDETI CUM ARATA SCANDURA RANDELUITA PE TOATE FETELE.
DECI CINE E INTERESAT DE CERINTA DIN INCEPUTUL TOPICULUI ?! SANATATE SI CER SENIN !
Postat 28 June 2011 - 06:41 PM
Nu am setul respectiv, dar iti pot raspunde la citeva nelamuriri.
Cum spui si tu, lazile metalice sunt pentru munitie (benzi cu cartuse).
Da, la unele kit-uri, nervurile sunt exagerate, tocmai pentru, cum zicea un prieten, sa pacalim ochiul intr-un mod frumos. Adica, daca erai facute la scara, erau superbe dar...nu se vedeau deloc! (2mm, nervura reala, impartit la 35 face 0,057 mm!). Acu', ca unii producatori de kit-uri exagereaza, e alta problema.
Acel rost dintre scinduri il faci prin gravare si apoi il evidentiezi prin umbrire
CA IN CAZUL LAZILOR DIN LEMN NATUR TREBUIESC FACUTE CHIAR DIN BAGHETE DE LEMN.
Nu, nici asa nu e bine! Pentru ca pina la urma ajungi tot la exagerare. Separat, ladita respectiva, facuta din baghete de lemn, arata foarte bine, insa pusa linga o lopata de infanterie, sa zicem, la scara 1/35 sau 1/72, arata exagerat, nereal, deci ajungi totde unde ai plecat. Ca exemplu: uita-te la filmele "apocaliptice", unde un val urias de apa vine peste un oras. Casele sunt mici, ca sunt machete la scara, dar stropii de apa desprinsi din val sunt aproape cit ...casele de mari!!! (ca de, legile fizicii nu le poti...reduce la scara! :whistle: )
Daca te deranjeaza acele "nervuri" poti sa le indepartezi prin slefuire. Apoi vopsesti lada si prin tehnici destul de simple, imiti lemnul.
http://www.cartula.r...ulare-lemn.html
#3 Useril este offline   caporalmusat
  • Postari: 1048
Postat 08 December 2011 - 06:45 PM
Salutare. Revin in acest topic pt ca mi-am luat acest set si in setul respectiv exista acele cutii pt benzi de mitraliera de tip Degtyarev DP- 27 mitraliera folosita mult in ww2 ori eu nu am ce face cu ele si asvrea sa le schimb tot cu ceva cutii de munitie ruseasca de orice calibru dar folosite in timpul razboiului rece si pana in prezent. .Sau alte efecte prelate, ranite , marmite si alte alea.. Am postat aici pt a nu deschide un topic doar pt a schimba niste pese (18 PT 6cutii )
