Forum Machete,Modelism,Hobby: Sfaturi compresor si airbrush - ebay - Forum Machete,Modelism,Hobby
#1 Useril este offline   shadow
  • Postari: 33
  • Inregistrat: 15-April 06
Postat 04 August 2010 - 07:35 PM
Salutari.
Am gasit un set tare interesant pe ebay.de, ce include un compresor destul de mic si cu doar 35 de db nivel de zgomot, plus 2 airbrush-uri si alte maruntisuri. Puteti sa imi dati un sfat avizat ? Credeti ca merita banii?
Pun link-ul cu produsele respective si specificatiile tehnice :
http://cgi.ebay.de/Airbrush-Kompressor-KAS...utorefresh=true
Si specificatiile :
Mini Airbrush compressor KAS18 pro-220 + + + Complete 9 pcs incl Mega Accessory Package!
with pressure regulator, automatic shut-off, pressure gauge and water, oil and maintenance free, very quiet 35db, ideal for working in confined spaces.
Power-saving by automatic shutdown upon reaching the pressure.
Perfect work through constant work pressure, which is achieved by a regulator,
included the complete airbrush Pistolenset.
Delivery:
Airbrushkomplettset KAS220 + + +
Piston compressor
CleanPot
Table Stand
Airbrush gun 0.2mm PAK81A
Double-action Trigger Air-Paint Control
Airbrush gun 0.3mm KAS130
Fabric hose
Flexible hose
Quick
Reducing
Technical data:
Volume: only 35dB
Single compressor oil free and maintenance free
Flow rate 23 l /
Pressure max. 4 bar
Voltage: 220-240V / 50Hz
Overload protection with automatic switch-off at 4 bar
Auto start at 2.8 bar
Weight: 3.6 kg
Dimensions: 24.5 x 13.5 x 17 cm
Power cable 1.9 m
Output: 1 / 8 "Airbrush Compressor (Maintenance Free)
Water
With pressure gauge
Manual engl.
8pcs. Airbrush Pistolenset
incl hose and original packaging
(Air pressure and Farbzulauf can be controlled with only one finger)
3m hose adapter
LE :
Am mai gasit o optiune
http://cgi.ebay.de/Mini-Profi-Airbrush-Kom...=item588903d994
Aceasta postare a fost editata de shadow: 04 August 2010 - 07:37 PM
  • Postari: 12670
Postat 05 August 2010 - 08:02 AM
Dupa specificatii este vorba de setul pus in vinzare si de Craciunoiu. Aerografele sunt niste clone Iwata, destul de bune.
Compresorul este bun, numai trebuie avut grija la timpul de utilizare ce nu trebuie sa depaseasca 20 de minute, dupa care o pauza de cel putin inca 20. Neavind rezervor de calmare, aerul este putin pulsator si, cel putin la cele de la Craciunoiu, au ceva probleme cu regulatorul de presiune ce nu functioneaza tocmai corect.
Daca merita banii? Avind in vedere ce-ti ofera eu zic ca da.
#3 Useril este offline   shadow
  • Postari: 33
Postat 05 August 2010 - 09:24 PM
Am incercat sa dau de topic-ul respectiv al lui Craciunoiu, dar nu l-am gasit. Poti sa imi dai un link?
Sau macar sa-mi spui la ce pret le avea el?
Si inca o chestie, caracterul acela pulsator al aerului va fi un impediment major?
#4 Useril este offline   GGG
  • Postari: 531
Postat 05 August 2010 - 11:35 PM
Depinde cum folosesti aerograful, pentru o vopsea diluata bine, care poti s-o dai la 1-1.5 bari, nu cred ca e problema. Cred ca "pulsatiile" intervin cand ai de vopsit suprafete mari, si iti trebuie ceva mai multa presiune.
Oricum...kit-ul merita toti banii.
Catre Z-mare o intrebare...nu merge sa-i ataseze un recipient mai sanatos ?
Bafta
  • Postari: 12670
Postat 06 August 2010 - 07:57 AM
Shadow, nu aveai cum sa gasesti pe net, Craciunoiu avea un magazin in magazinul Cocor, acolo arau vindute. Pretul, nu-l mai stiu, poate ne ajuta careva. Nu stiu daca mai are si in magazinul nou, pe undeva prin Tei.
GGG, nici o problema, cu putina munca si ceva scule, se poate atasa un rezervor de 3 - 5 litri, numai bun pentru nevoile noastre!
#6 Useril este offline   anstro
  • Postari: 427
  • Inregistrat: 12-January 10
  • Interests:Aviatie
Postat 06 August 2010 - 10:33 AM
Daca imi aduc bine aminte, pretul era undeva la 400 de lei.
#7 Useril este offline   shadow
  • Postari: 33
Postat 06 August 2010 - 05:17 PM
Ce inseamna daca are in plus un tank de 3 litri? :drinks:
Dar de asta ce parere aveti?
http://cgi.ebay.de/Airbrush-Kompressor-KAS...=item58890f7eb3
Mersi frumos.
Aceasta postare a fost editata de shadow: 06 August 2010 - 05:19 PM
  • Postari: 12670
Postat 07 August 2010 - 08:05 AM
Inseamna ca poti incaraca acel rezervor, in citeva minute (depinde de compresor si dimensiunile rezervorului), apoi poti vopsi linistit, timp in care motorul se raceste. Cind presiunea scade sub o anumita valoare, motorul porneste si ciclul se repeta. Apoi, in cacel rezervor se poate decanta eventualul condens si ulei, astfel ca acestea nu-ti ajung pe macheta.
In privinta compresorului, ce sa zic? La nemteasca mea, vad ca nu are rezervor de calmare (acel 0,3L este aproape conductaraia!), deci compresorul va merge tot timpul cind vopsesti, histerezisul este de un bar, dar, ce este mai important, nu vad si nici nu sunt date informatii despre regulatorul de presiune. Lipsa regulatorului este un neajuns in cazul vopsirii cu aerograful. (vezi si: http://www.cartula.ro/Articole/Unelte-inst....-comprese.html )
#9 Useril este offline   flo
  • Postari: 2480
Postat 20 August 2010 - 04:25 PM
Cunoaste cineva produsul:
http://modelism.ro/rowi-airbrush-double-ac...4531-p-312.html
Daca da, il rog sa ne spuna cateva vorbe despre acest aerograf.
Multumesc.
#10 Useril este offline   AdiP
Postat 20 August 2010 - 05:34 PM
Salut Florin
Daca este intr-adevar Rowi, ar trebui sa coste putin mai mult de-atat. Din ceea ce vad, e un aerograf fara mari pretentii insa utilizabil cu brio pentru modelism. Poate putin mai dificil de lucrat cu el ,datorita obturarii zonei de vopsit de catre cupa amplasata pe axa.
Cupa de 7 ml fixa, duza de 0.3 mm, coroana simpla si trigger dublu rol (deci masinarie dubla actiune), alimentare prin gravitatie. Reglaj fin al debitului de vopsea prin intermediul opritorului de coada, cu putin antrenament/indemanare si binenteles presiune mica - se pot trasa linii subtiri, undeva la 0.5 mm mm latime.
Acelasi lucru (repet, daca este intr-adevar Rowi), se gasea pana mai curand la Hobbyx, la 145 lei si ii zicea BD-130.
Eu lucrez cu ceva asemanator, cupa tot de 7 ml pozitionata insa pe dreapta masinii (alimentare prin gravitatie), interschimbabila cu recipient de 10 ml ce lucreaza prin absorbtie.
Daca te bate gandul sa il achizitionezi, eu iti recomand sa o faci. Musai compresor cu regulator de presiune la el, pentru a scoate tot ce poate da masinaria.
Oricum, sa vedem ce zic si ceilalti.
Adi
Aceasta postare a fost editata de AdiP: 20 August 2010 - 05:35 PM
#11 Useril este offline   flo
  • Postari: 2480
Postat 20 August 2010 - 05:51 PM
Multumesc Adi.
  • Postari: 12670
Postat 24 August 2010 - 08:15 AM
Este o copie Iwata, destul de bine facuta. Am lucrat cu asa ceva, eu zic ca merita banii! Normal, cum zicea si AdiP, alaturi de un compresor.
#13 Useril este offline   flo
  • Postari: 2480
Postat 24 August 2010 - 04:46 PM
Multumesc pentru sfaturi Z-mare.
Este in lucru. Ma chinuiesc sa gasesc un strungar cu chef de munca, evident pentru fitingaraie.
#14 Useril este offline   razvi00
  • Postari: 8
  • Inregistrat: 26-August 10
  • Interests:airbrush
Postat 26 August 2010 - 09:48 PM
Vezi postareaflo, la 24 Aug 2010, 17:46, a spus:
salut flo,
Asa cum a zis si AdiP , aerograful de mai sus intr-adevar este un BD(bun doar pt vopsea pe baza de apa).am si eu unul...l-am luat cu 1 mil si un pic.Pentru pictura si detalii nu il recomand..e slab...doar pentru fonduri.Eu l-am incercat o data ...acum zace pe dulap...mai am un master g44(o copie f buna dupa iwata) pe care nu il mai folosesc...dar il recomand ca fiind bun(NU PT VOPSELE PE BAZA DE DILUANT).Pentru detalii ai nevoie de ceva mai bun...dar pleaca de pe la 300-350 RON.Bafta
