Forum Machete,Modelism,Hobby: 1966 FORD MUSTANG - Forum Machete,Modelism,Hobby
1966 FORD MUSTANG 1/25 AMT
#1 Useril este offline   saber
  • Postari: 214
  • Inregistrat: 25-June 08
Postat 13 August 2009 - 07:45 PM
We're together again with a new work,I had recently started
OK..heres the some pictures of the construction phase
Good modeling
Now ready to paint job....
Aceasta postare a fost editata de saber: 13 August 2009 - 07:43 PM
#2 Useril este offline   gobi71
  • Postari: 1267
  • Interests:navomodelismul
Postat 13 August 2009 - 08:28 PM
there is a lot of interes for this car,saber.god choice,enjoy.what colour did you chose for it?metalic dark-grey?
#3 Useril este offline   saber
  • Postari: 214
Postat 13 August 2009 - 08:33 PM
Vezi postareagobi71, la 13 Aug 2009, 21:28, a spus:
Thanks,I choosen color non metalic red
Postat 14 August 2009 - 10:40 AM
Hi Saber!
I have two questions:
- did you primed and sended the body?
- the chrome parts you got from the kit are ok, or you think to use Bare metal Foil / Alclad Chrome?
I will follow with interest your build, hopefully you post many pictures!
Regards,
Tibi
#5 Useril este offline   Messerschmitt
  • Postari: 797
  • Inregistrat: 01-March 07
Postat 14 August 2009 - 01:46 PM
Veri nice car, indeed! Let`s hope the model will be the same. :whistle:
#6 Useril este offline   saber
  • Postari: 214
Postat 14 August 2009 - 07:24 PM
Vezi postareatibi22, la 14 Aug 2009, 11:40, a spus:
Hi Saber!
Regards,
Tibi
Hi Tibi,
Yes I painted the primer to surface with Tamiya (Fine Primer white one)
I use chrome parts from the box.But some palces will paint Alclad Chrome.
THank you
#7 Useril este offline   michi
  • Postari: 228
  • Inregistrat: 29-June 08
Postat 14 August 2009 - 09:30 PM
Hello Saber!
Nice to find W.I.P. like these.
I have a little question: does the engine is in its final stage?
I put this question because of the lack of wiring. And it is a pity not to do this.
At this scale you can do great things.
Otherwise very good project.
I'll watch closely you W.I.P.
Aceasta postare a fost editata de michi: 14 August 2009 - 09:31 PM
#8 Useril este offline   saber
  • Postari: 214
Postat 15 August 2009 - 08:12 AM
Vezi postareamichi, la 14 Aug 2009, 22:30, a spus:
Hello Saber!
Thank you,
Habits of the first engine start,but it still has something to do,for example, to add details, such as cable
Good modeling
#9 Useril este offline   Pletila
  • Postari: 323
  • Inregistrat: 14-January 05
Postat 17 August 2009 - 10:47 AM
Hi saber
i have this kit to,and i have started the build, but you are way ahead of me :).For now i don't know what color to chose.Keep working.I will watching you.
Succes.
#10 Useril este offline   saber
  • Postari: 214
Postat 17 August 2009 - 08:09 PM
Thanks Pletila,
Red color I've choose.
Main paint job near the finish.I've prefered acrilic satin color.Brightness obtained by going to varnish
Good modeling.
Postat 17 August 2009 - 08:30 PM
Hi Saber!
The paint job is very good so far! Do you spray some clear gloss on the body? In my opinien it sould be, because this cars are generally very shine!
Regards,
Tibi
#12 Useril este offline   saber
  • Postari: 214
Postat 17 August 2009 - 09:48 PM
Vezi postareatibi22, la 17 Aug 2009, 21:30, a spus:
Hi Saber!
Regards,
Tibi
Hi Tibi,
There are only painted on the body.Pictures were taken in daylight,has made it shine
Thanks
Aceasta postare a fost editata de saber: 17 August 2009 - 09:56 PM
#13 Useril este offline   michi
  • Postari: 228
Postat 17 August 2009 - 10:23 PM
Hello,
Very good applied color. It seems to be thin. This is very good because you don’t loose details.
I’m impatient to see how it looks after varnishing.
Very well done so far.
#14 Useril este offline   Pletila
  • Postari: 323
Postat 22 August 2009 - 08:35 AM
It looks great on red. Maybe some withe trims? Two strips from front to back? Something like GT40? Just asking.
GO!GO!GO!
One more question.
Behind the door,is an empty space,and i want to know how the window goes up and down.When the window is up,she has to close al the spaces, but for that to happend,it has to be an extra pole where i have put the green line on your picture.
Here are two pictures of 1967 mustangs one uith the pole and one without the pole.When that window is up there is a pole, and there is a small window on the back and when the window is down,there is no pole and no little window.
How is that? Is that little window, retractable and she goes down to?
  • Imagine atasata: mustang.JPG
  • Imagine atasata: mustang_cu_stalp.jpg
  • Imagine atasata: mustang_fara_stalp.jpg
Aceasta postare a fost editata de Pletila: 22 August 2009 - 08:35 AM
#15 Useril este offline   saber
  • Postari: 214
Postat 22 August 2009 - 06:29 PM
Thank you so Pletila,
Yes, that little window, and the expenses recovered.There are similar systems in many older American car.
