Forum Machete,Modelism,Hobby: A-1H SKYRAIDER - Forum Machete,Modelism,Hobby
A-1H SKYRAIDER Italeri 1/48
#1 Useril este offline   saber
  • Postari: 214
  • Inregistrat: 25-June 08
Postat 28 October 2008 - 09:39 AM
I try to build this most famous aircraft of "Vietnam War"
The box
Firstly I have to say this kit not so good only ok.If you want to build an Skyraider I want to offer Tamiya
See
Aceasta postare a fost editata de saber: 28 October 2008 - 09:42 AM
#2 Useril este offline   uhu
  • Postari: 851
  • Inregistrat: 12-August 05
Postat 28 October 2008 - 04:01 PM
I have both the kits, the Italeri is assembled but not painted. The Italeri has raised panel lines while the Tamiya is of the engraved panel lines type. If you want a simple build (and cheap) than you can make the Italeri which with some amount of extra work will turn into a nice representation of the Skyraider.
#3 Useril este offline   saber
  • Postari: 214
Postat 29 October 2008 - 02:36 PM
#4 Useril este offline   saber
  • Postari: 214
Postat 02 November 2008 - 04:17 PM
During building this kit my friend Bogdan"bogy" who said me "the air intake positioned up on the engine it's wrong"..well
than I started to work on air intake...
putty and some part add on...
bottom side painted with some shade...
I think air intake is OK....if not I can do it just this...
Thanks Bogdan "bogy"
#5 Useril este offline   saber
  • Postari: 214
Postat 02 November 2008 - 06:42 PM
#6 Useril este offline   saber
  • Postari: 214
Postat 09 November 2008 - 07:43 PM
Ok..lets some update
#7 Useril este offline   saber
  • Postari: 214
Postat 18 November 2008 - 07:36 PM
Well.....I did dirty look on panel lines
#8 Useril este offline   uhu
  • Postari: 851
Postat 18 November 2008 - 08:40 PM
Hello, nice work so far. I have a question. How did you obtain the dirty panel line effect on raised panel lines ???
#9 Useril este offline   saber
  • Postari: 214
Postat 18 November 2008 - 09:54 PM
 uhu, la 18 Nov 2008, 20:40, a spus:
Thanks
I can just to say sipmle prosses.Tamiya X-1 and glass cleaner to thin the paint.
X-1 is 1/1 parcent thin with glass cleaner on the case
This blend paint on panel lines by thin brush.After(none dry yet!! )
to flight course wash the panels by wet large brush.
#10 Useril este offline   dflc03
  • Postari: 223
  • Inregistrat: 22-June 08
Postat 19 November 2008 - 07:05 PM
 saber, la 18 Nov 2008, 21:54, a spus:
Thanks
Hello!
Nice job! One more question - when you say wash panels with large wet brush you mean large brush
wet with water or wet with blend paint?
Aceasta postare a fost editata de dflc03: 19 November 2008 - 07:06 PM
#11 Useril este offline   saber
  • Postari: 214
Postat 19 November 2008 - 08:29 PM
Well...sorry I'd forgat it...firstly lets edit to the paint,it has being XF-1 as you see on the photo
Large brush wet with glass cleaner..
Thank you
