Forum Machete,Modelism,Hobby: Berlin 1945 - Forum Machete,Modelism,Hobby
Berlin 1945
#1 Useril este offline   TheBushmaster
  • Postari: 1
  • Inregistrat: 25-June 08
Postat 26 June 2008 - 10:04 AM
Hi;
This is the last figure I've painted.I Hope you like it.
Producer: Dragon
Scale:1/35
All painted in enamels and finished in oils.
#2 Useril este offline   alexie
Postat 26 June 2008 - 10:37 AM
:clapping: the English language :clapping:
- The Best camouflage
- Column capitel = Bayer Aspirin Efervescent?
- Debris "Sedona Red" = brick?
:clapping: Nice! Bis! Bis!
Translatror
Imi place foarte mult camuflajul, creaza impresia ca figurina este la 1/16.
Nu inteleg ce reprezinta fragmentele visinii.
As dori sa vad si alte opere mai vechi ce-i poarta semnatura.
Postat 26 June 2008 - 11:25 AM
Very, very nice work on figure. I like what you did on camouflage. But there is also something very bad there: the standing column. Remove it because it ruins everything or at least paint the base ("capitel" like alexie said, I don't know if this is the correct word) with the same color as the column, preferably white-yellow. Of course this is only my opinion, I can be wrong. I told you this because you did an exceptional work with the rest.
Postat 26 June 2008 - 12:04 PM
Base of the column. The capitel is on the upper side. Anyway it dosen't resemble any stile of capitel known.
Remove that and it will be OK I guess. Or you can do a base from some kind of putty after you have studied pictures .
Also the position of the panzerfaust is not propper. The germans use to stick it under the arm to fire.
Take this as advices and not as criticism. Happy modelling Bushmaster.
#5 Useril este offline   Panzer_Grenadire
  • Postari: 893
  • Inregistrat: 11-October 05
Postat 26 June 2008 - 12:15 PM
Very nice camouflage on the trousers the Bushmaster, congratulations. Not only the colours, but also the model, oak leaf, look exactely like they should. the one from the parka, the peadot, I think it is the early model, with more brown than the late one.
As my colleague Wurger said, the figure not correctly holds the Panzerfaust. Also further details could be added, for instance the tabs of the bread bag. If you look and on the figure, you will notice them, these are quite visible and if you add them, these will improve the appearance of the figure.
I also enjoyed the scratches of the mess tin as well as the ammunition pouches.
Thanks for posting and looking forward to seeing other works, of course I would prefer on the same topic..... :clapping: :clapping:
#6 Useril este offline   bogdy
  • Postari: 85
  • Inregistrat: 12-February 12
  • Interests:Modelismul, desenul, muzica
Postat 05 April 2012 - 10:09 PM
Very nice! Well done, master! I like the camouflage. The soldier is very expressive! Congratulations! :good: :clapping:
#7 Useril este offline   bogy
  • Postari: 1381
  • Inregistrat: 26-May 05
Postat 06 April 2012 - 06:57 AM
Nice work but...it's true, the corect pozition for the Panzer Faust it's under the arm. The German army have the Panzer schreck (something like a bazooka) wich have the corect fire position on the shoulder.
What I did not understand, is the flag. At that time, German aviation was almost nonexistent. Or those flags were used in this way (for signal), in the first years of war, when the Luftwaffe was present and active. But ultimately, this is just my opinion.
Postat 06 April 2012 - 10:49 AM
Topicul e vechi de 4 ani, credeti ca-l mai citeste autorul, care, daca ne uitam bine, de atunci nu a mai intrat pe froum???!!!!
Ca atare, pina una alta, se inchide.
