[/center]
1/18 scale Lockheed Martin F-16CJ Fighting Falcon Block 52 Hellenic Air Force
BBI - Elite Force conversion & scratchbuild
The following article is to describe step by step the 1/18 scale Lockheed Martin F-16CJ Fighting Falcon Block 52, currently flying with Hellenic Air Force, conversion using the BBI - Elite Force toy model kit, bought from the States a couple of years before for less than $60.
[center]
Despite my enthusiasm when I finally got this 1/18 model in my hands, as soon as I opened the box which exceeds in length the 3 feet (!!!), I realized that I would face hard time and massive scratch building and I'd need to spend hundreds hours on my hobby bench to make it look descent. In the substance, it is not even a model to assembly but a game for children which could be ready in less than 2 minutes. The detail convinces only if you look the model from a distance while points such as landing gear system, engine nozzle, panel lines etc are real dramatic. Luckily, the model is accurate on dimensions and could possibly be used as a F-16 exhibit model that do not interest on conformity of colors, special details etc.
[center]
So, I decide to begin the building from the zero and give life in this 82cm long monster with no detail (comparing to scale models by Hasegawa, Tamiya etc) but however this 1/18 F-16 toy has almost unlimited possibilities of becoming a high detailed scale model. It should be noticed that the model's airframe comes straight from the box already sealed and I had to open it and work it from inside. That's a hard work to do, because the fuselage remains stuck with internal reinforcing possessors and metal supports & screws that I should locate and carefully remove without causing any damage on plastic material.
[center]
82cm long beast, immediately after opening of packing box. I am already start thinking about finding the proper window to place this Falcon[/center]
By selecting heavy metal on my CD player (in order to I become aggressive and get the "Friday 13th" feeling) and using a saw and a Dremel tool, I opened the fuselage, the basic airframe pieces were cut and useless parts such as landing gear, engine nozzle, a part of the air intake etc were removed and led to the garbage.
[center]CHAPTER I - Engine's 1st stage blades & afterburner construction
[/center]
Beginning the construction from behind, I should first scratch build the Pratt & Whitney F100 turbofan engine (F-16CJ Block 52) nozzle, the afterburner compartment etc as detailed as a curious and indiscreet eye could see. Considering the huge dimensions of the model, I should theoretically scratch build almost everything! Using plastic cards, my new X-Acto blade, F-16 related bibliography, photographs and the T.O service manual used for the real F-16, I started.
[center]
Building the engine's air intake & blade fans was quite easy. Using an old 1st aid kit tape cap which just fit on 1/18 diameter engine 1st stage blade fans, I placed carefully plastic blades as shown in the following pictures. Molding some epoxy putty, I build a basic item of a cone, then stuck some steel pins on it and removed them after 20 minutes, as soon as the epoxy putty was solid rock. Spinning the epoxy item with the Dremel tool and sanding as required, I formed in to a cone shape and finally I placed a pitot tube sensor on the top of the cone spinner as shown in the real Pratt & Whitney F100 turbofan engine pictures.
[center]
Aceasta postare a fost editata de Nick_Karatzides: 16 September 2009 - 05:12 PM
